17 years agoa strange problem!
module zhengxing(clk_200M, rst, data_in, data_out ); input clk_200M; input rst; input data_in; output data_out; reg data_out; reg [2:0]counter; reg [1:0]state; parameter low...
17 years ago --- Quote Start --- Hi. I assume you have your block conneted in the right way. Did you check your reset signal polarity ? What is your clock frequency and what is the toggling rate of your data_in? Kind regards Gerd --- Quote End --- oh ! i changed the name of this module in my project in this afternoon, and its name is zh.v,and use it in the zhengxing.bdf ,so it's no problem aboat this project! and i also use the signaltap to see the state machine,but it doesn't work.when i press the reset ,the register of counter and data_out is be changed to '0',but when i don't press the reset ,the register of counter is changed from '0' to '3' all the time,and the state machine has no reaction. the signal of clk_200M is from pll ,it's 200M,and data_in is the input of sqare wave ,and the rst is the input of reset, the out _data is the output of square wave afte this module ,and the square wave of data_in is under 10M,
