student8
2 years agoA signal does not exist, but it does exist when using a signal tap to capture it.
I designed a startup signal in the module, but after powering on, I found that the module did not perform the expected function. Using signal tap, it was found that subsequent signals driven by this ...
FvM
2 years agoYou should be able to explain the "startup signal" scheme by giving some example code.
A "popular" reason for similar problems is missing synchronization of reset release. Respectively design behaviour depends on arbitrary routing delays and changes e.g. when adding Signaltap.
