16 years agoA question regarding MAX II I/O supply voltage
Hi everyone! Been searching the literature and googling around, but I've found no indication as to whether it is a problem to connect the VCCIO pins of the MAX II device to a non-standard volt...
16 years ago --- Quote Start --- I am expecting to see roughly a Vih and Vil of 0.65*Vccio and 0.35*Vccio respectively, and a Voh and Vol of 0.75*Vccio and 0.25*Vccio respectively. --- Quote End --- That's reasonable. MAX II I/Os are CMOS gates supplied by VCCIO, they have a slight threshold asymmetry to better fit the LVTTL requirements, but basically comply with respective JEDEC level specification over the 1.5 to 3.3V supply range.
