17 years agoA bug in qmegawiz command line?
I want to use qmegawiz command line generate a 2 ports ram with clock_a and clock_b. "qmegawiz -silent module=altsyncram -f:ram_params.txt myram.v" the content in file ram_params.txt as foll...
17 years agoIn "Quartus II Handbook Version 8.1 Volum 2 Design Implementation and Optimization"->The MegaWizard Plug-In Manager->Ports and Parameters->Strategies to Determine Port and Parameter Values
would you give me an example with 'port and parameter configuration in command line' ?
