16 years ago8b10b clock recovery?
Would it be possible to use an Altera FPGA (Arria II GX or Cyclone IV GX) to snoop on a 2.5 Gbps PCI Express link (via the PIPE interface), recover the clock and send out the recovered clock to one o...
16 years agoJust to tie up all loose ends:
--- Quote Start --- Second best case jitter is to recover the clock and use it to trigger the scope viewing non-reclocked data. --- Quote End --- How did you recover the clock? I have found no circuit that actually outputs the clock from a 2.5 gbps 8b/10b diff signal. If the solution is fairly simple i could build this circuitry into the 'SMA board' and get better overall result. Thanks.
