16 years ago8b10b clock recovery?
Would it be possible to use an Altera FPGA (Arria II GX or Cyclone IV GX) to snoop on a 2.5 Gbps PCI Express link (via the PIPE interface), recover the clock and send out the recovered clock to one o...
16 years ago --- Quote Start --- The practical problems of tapping a PCIe link without disturbing it should be well considered. A differential active probe would be the best solution. A matched resistive "power divider" involves a 6 dB attenuation. --- Quote End --- In the proposed measurement setup, the PCIe link will not be tapped but rather terminated (in the scope). In the most simple setup case, the 'SMA board' is plugged directly into a motherboard PCIe connector: Transmitter => PCIe Slot => 'SMA board' => Oscilloscope Note that the only purpose of the 'SMA board' is to connect the two signals in the PCIe signal pair to the single-ended scope channels. The intent is to avoid using a probe at all and instead use the 'infinite bandwidth' coaxial cable and the termination in the scope, essentially extending the transmission line all the way into the scope's 50 ohm termination. --- Quote Start --- Most PCIe system are using a spread spectrum reference clock, which adds additional jitter to any PLL or recovery circuit, that locks to the clock. All PCIe Tx signals are however locked to the 125 MHz reference clock, so you may want to try, if this clock isn't suitable for triggering the measurements. It's jitter should be "two PLL steps" lower than your intended CDR circuit. --- Quote End --- Assuming that the jitter can be ignored (the extender board will only have some three inches long traces), is there any reason why the above setup could not be useful for a 'rough' measurement of the PCIe eye diagram? I am essentially interested in knowing whether the extender board substantially changes the signal quality. My plan is to first plug the 'SMA board' into the motherboard PCIe slot and capture the signal forms. Then install the extender board and plug in the 'SMA board' on top and do the same measurement. If the two measurements are roughly equivalent, then the extender board should be safe to use. Also, given that the scope is triggered on the data, SSC should not affect the measurements. Thanks.
