10 years ago
7- Segments pin assignment for Cyclone IV EP4CE6E22C8
Hello:
I wrote simple program to count on 7 Segments Display in my board Cyclone IV EP4CE6E22C8.
module seg(
    input clk,
    output segA, segB, segC, segD, segE, segF, segG, segDP
reg  cnt;
always @(posedge clk) cnt <= cnt+24'h1;
wire cntovf = &cnt;
reg  BCD_new, BCD_old;
always @(posedge clk) if(cntovf) BCD_new <= (BCD_new==4'h9 ? 4'h0 : BCD_new+4'h1);
always @(posedge clk) if(cntovf) BCD_old <= BCD_new;
reg  PWM;
wire  PWM_input = cnt;
always @(posedge clk) PWM <= PWM+PWM_input;
wire  BCD = (cnt | PWM) ? BCD_new : BCD_old;
reg  SevenSeg;
always @(*)
case(BCD)
    4'h0: SevenSeg = 8'b11111100;
    4'h1: SevenSeg = 8'b01100000;
    4'h2: SevenSeg = 8'b11011010;
    4'h3: SevenSeg = 8'b11110010;
    4'h4: SevenSeg = 8'b01100110;
    4'h5: SevenSeg = 8'b10110110;
    4'h6: SevenSeg = 8'b10111110;
    4'h7: SevenSeg = 8'b11100000;
    4'h8: SevenSeg = 8'b11111110;
    4'h9: SevenSeg = 8'b11110110;
    default: SevenSeg = 8'b00000000;
endcase
assign {segA, segB, segC, segD, segE, segF, segG, segDP} = SevenSeg;
endmodule
then i connect these pin assignment
clk --> pin 24
segA --> 143
segB --> 144
segC--> 141
segd --> 142
segF -->138
segG -->2
segDP --> 3
after i run this code , only the blue small LED works not the 7Seg !!
now how can i run the 7 Seg ?
also how can i count the & seg by pressing the push bottom ?
thank you
    I dont have the csv file , its a Chinese board. how can i get it ?
    zr tech v2.00
    Which board do you use? For the boards I have used I was able to find a .csv file with the pin assignments, which I could import. That, in combination with a board-specific top layer for the mapping of the ports to the pins, makes it easier to see the connections and know the assignment has been done correctly.
    Seems like the following part of the code will keep always the variable BCD_new at the same condition:
