14 years ago
5V i/O
I need to have TTL (+5V for HIGH) inputs and outputs from an Altera DE0 board. Is there any easy way to configure it for I/O pins to operate at 5V?
Due to time constraint, I am trying hard to avoid making a board with voltage translators now!
Any suggestions?
    I myself using DE0 with 5V ICs. You can send a 3.3V LVTTL signal to a 5V TTL, that's ok. But for taking 5V signals as an input I use a serial 330 ohm resistor to restrict current and a parallel 3.3V zener diode before FPGA input. Works satisfactory for me for low frequency applications.
    According to TTL specification, 3.3V level is sufficient, because TTL Vih,min is 2.0 V. If you want to drive 5V CMOS with Vih,min of 3.5V, a level translator can't be avoided.
    on DE0_v.1.1_CDROM\DE0_CD-ROM_v.1.1\Schematic\DE0_V12_RELEASE.pdf page 17, all the VCCIO are connected to VCC3p3.
    The VCC3p3 comes from the REG3 on page 18 specific for 3.3V only, plus the VCCIO has a maximum rating of 3.9V (cycloneIII device datasheet P1) plus VIH max is VCCIO+0.3V.
    So I guess that you do need voltage translation.
    Regards.
