ShivaKi
1 year ago5CEBA7F27C8N JTAG Interface Debugger Support
Hello, USB Blaster UG-USB81204 is considered for Debugging Cyclone V (5CEBA7F27C8N) 1. What is the maximum TCK frequency that is supported by USB Blaster UG-USB81204 2. What will be minimum and...
FakhrulA_altera
1 year agoHi ShivaKi,
You may refer to the timing spec more detailed in the datasheet: Cyclone V Device Datasheet
regards,
Fakhrul
- ShivaKi1 year ago
Hello Fakrul,
For USB Blaster Debugger also, the same timing specifications mentioned in Cyclone V datasheet will be applied? Please confirm
with regards
Shiva
- FvM1 year ago
the only relation between USB-Blaster and Cyclone V timing specification mentioned in previous post is that USB-Blaster surely fulfills Cyclone V requirements. That wasn't your question as far as I understand.
I tried to answer your original question in cross-posted thread https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/USB-Blaster-Download-cable-Timing-Specification/m-p/1643839
Still not clear to me what you want to achieve. If you have specific questions not directly related to Cyclone V debugging, you should ask explicitely.
Frank
