50Mhz to 1hz Clock ic
Is there an ic that can convert a 50Mhz clock to 1hz?
so write code that describes that behaviour. The point of FPGAs is to integrate all that stuff on one (reconfigurable) digital ic.
I am working with an FPGA, I'm designing a math game, I need a 60 second countdown timer.
If you want a a clock with a 50% duty cycle, then count to 50M/2 -> 25000000 and I sometimes use a clock in the <10 Hz range for signals like heartbeats, or well clocks (those that count seconds), so although it is uncommon it has its advantages (mainly in simulation time).
Since you are asking in this forum I guess you are working with a FPGA or CPLD. Then you don't need any IC; simply instantiate a counter (at least 28bit wide) and reset it when it reaches 50'000'000. The reset signal will pulse at 1Hz frequency.
Anyway, what's your purpose? Creating a 1Hz clock generally doesn't make sense: the common practice is using clocks in the MHz range and driving clock enable pins to get the proper switching rate.
