9 years ago50Mhz to 1hz Clock ic
Is there an ic that can convert a 50Mhz clock to 1hz?
9 years agoIf you want a a clock with a 50% duty cycle, then count to 50M/2 -> 25000000 and I sometimes use a clock in the <10 Hz range for signals like heartbeats, or well clocks (those that count seconds), so although it is uncommon it has its advantages (mainly in simulation time).
