15 years ago4-QAM output error
I am trying to build a 4-QAM on an Altera FPGA and am having problems with the simulation on ModelSim. Attached to this thread is my code "qam4.vhd" which is the 4-QAM code and "testbench_qam4.vhd" which is the testbench for the code. Can someone tell me why am i getting the results as I am getting in ModelSim as attached in the file "QAM_ModelSim_error.jpg". the real output and imag output don't seem to match what I coded in the file "qam4.vhd". The input data is extracted from the file "data.txt" Thank you so much, any help will be much appreciated.4 Replies
Thank you so much Kaz, I finally got it working. Simplicity as you suggested, was the way to go. =)
By my initial post I meant you don't need any extra code apart from mapping input bits to output directly. You don't need buffer or enable. just straightforward mapping.
Thanks Kaz for the reply and help, but somehow, I am still getting errors in the results =( as attached in the file " QAM4_ModelSim_error_21_04_2011.jpg"
I noticed that my output takes up 2 clock cycles each, which I don't understand why this is happening. Will you help me to look through the file? I am pretty new to VHDL and I really want to solve this problem. Attach is the file amended as you recommended. Thanks again, really appreciate your help. - Altera_Forum
You migth just say:
if input = "00" then real <= "11"; -- -1 imag <= "01"; -- +1 elsif input = "01" then...
