Vocabularix
5 years ago3V3 LVDS on MAX10
Hello all, I am designing a board containing the 10M04SAU169, and I will need several LVDS channels to communicate with the same board (there will be multiple boards containing this design in the sy...
Vocabularix
5 years agoThank you for your answers, I have a few more if you don't mind :
Is there a differential standard that I could use with 3,3V VCCIO ? Would I get a better data rate using Bank 3 IOs ?
I saw that the 10M08E144 Eval board powers its IOs with 3,3V, and uses its IOs in differential mode (100 ohms terminated). What is the "protocol" used ?
AminT_Intel
5 years agoHello,
There is no differential standard with that can use with 3.3 V VCCIO in Max 10. You can refer to Max 10 I/O Standard table from this link on table 4 page 9
Thank you.
