8 years ago3rd party boot flash memory in ASx4
Hi, Need guidance on using a 3rd party configuration NOR flash for Cyclone V. the configuration scheme is ASx4. Altera and all other major vendors were stoped the production of low density N...
8 years agoHi,
--- Quote Start --- Thank you Anand, I would like to use the 3rd party device instead of Altera EPCQA devices since they are come in a relatively big package, SOIC8. The attached link "Altera_compatibility_chart_flash_dram" does not work. Do you know on a tutorial on how to configure the Cyclone V in ASx4 scheme using 3rd party device? BR Yoav Katz --- Quote End --- we cannot guarantee if using non-Altera (Intel PSG) flash devices such as Micron or Spansion or Cypress or Windbond will work successfully with our software tools and FPGA devices or not. For Active Serial configuration mode, we only support EPCS, EPCQ, EPCQA and EPCQL device flash memory. Thus you need to use EPCS, EPCQ, EPCQA or EPCQL flash memory devices for Active Serial configuration scheme on Altera (Intel PSG) FPGA devices. We have never mentioned promoting Micron or Spansion or Cypress or Windbond device officially support for Active Serial configuration scheme on Altera (Intel PSG) FPGA. We do not perform any testing or validation on these devices for Active Serial configuration mode. Thank you. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
