18 years ago32-bit SSRAM must have byteenable for Nios II?
One question - For 32-bit external SSRAM (or async. SRAM), does it have to have byte write mode enabled in order to work with Nios II processor? In other words, can Nios II handle all instruct...
18 years agoHmm, I got the following silly example working on DE2-70, but haven't yet written a more robust memory control, assigned timing constraints, used a PLL, or used the burst mode. Also, I don't have the Cyclone III kit, so it'll likely take some adoption to get it running.
The example waits for a char c over the serial port and it, as well as c+1 and c+2 in a buffer, then proceeds to replay the whole buffer. The char '0' resets the buffer. Unlike what I suggested and what is recommended everywhere, using an inverted clock didn't work well for me. The essence is this (WARNING, this isn't production quality code, just a quick example):
assign oSRAM_CLK = iCLK_50;
assign oSRAM_ADSP_N = 1; // We use ADSC#
assign oSRAM_BE_N =~0; // byte write enable
assign oSRAM_CE1_N = 0; // chip enable
assign oSRAM_CE2 = 1; // chip enable
assign oSRAM_CE3_N = 0; // chip enable
reg SRAM_D_ena = 0;
reg SRAM_DPA_out = 0;
reg SRAM_D = 0;
assign SRAM_DPA = SRAM_D_ena ? SRAM_DPA_out : 4'hZ;
assign SRAM_DQ = SRAM_D_ena ? SRAM_D : 32'hZ;
/* Demo state machine: When we get a serial char, we add it to the buffer
and prints the whole buffer again */
reg state = 0;
reg wp = 0;
reg rp = 0;
always @(posedge iCLK_50) begin
// Set up default values so that writes below are one-shot
oSRAM_ADSC_N <= 1;
oSRAM_GW_N <= 1;
oSRAM_ADV_N <= 1;
oLEDR <= state;
case (state)
0: begin // wait for input
oSRAM_OE_N <= 1; // close the SSRAM DQ drivers
SRAM_D_ena <= 1; // be ready for writing
if (rs232in_attention) begin
oSRAM_ADSC_N <= 0;
oSRAM_A <= wp;
oSRAM_GW_N <= rs232in_read_data == 48;
SRAM_D <= rs232in_read_data; // WRITE!
state <= 10;
if (rs232in_read_data != 48)
wp <= wp + 1;
else begin
wp <= 0;
state <= 0;
end
rp <= 0;
end
end
1: begin // wait a cycle just in case
state <= 2;
SRAM_D_ena <= 0; // Turn off the drivers
oSRAM_OE_N <= 0; // Open the SSRAM drivers
end
2: begin // issue read
oSRAM_ADSC_N <= 0;
oSRAM_A <= rp;
rp <= rp + 1;
state <= 3;
end
3: state <= 4; // READ latency
4: state <= 5; // READ latency
5: begin
// receive data
rs232out_write_data <= SRAM_DQ; // READ!
rs232out_write_enable <= 1;
state <= 6;
end
See the attachment for a full example for the DE2-70. If someone in the Santa Clara area could lend me a Cyclone III kit, I could probably adopt it to that.
