15 years ago3 NODES IN JTAGCONFIG -n SHOWN . How to delete one?
Hello, I'm doing altera tutorial project "hello word small" FPGA is CycloneIII 3C25 Software Quartus II 10.1sp1 Web Edition NIOSII EDS 10.1 sp1 Cable USB-Blaster SOPC ...
15 years agoYes, but are you keeping the QII programmer window open after programming your FPGA image (SOF, POF) to the FPGA? This is a requirement for any IP with OCP limitations. On the FPGA, the OCP just queries the host (PC) every so often (over JTAG) and if the host isn't "there", it stops/times out the IP that is using it. I'm assuming that it's your Nios II processor that's causing this. You can downgrade to an "e" core as it has no such restrictions...if you like.
Regards, slacker
