14 years ago2.5V VCIO for Configuration Pins
I am using a Cyclone III. I want to use the LVDS IO on Bank 1. I assume that I must set the VIO for Bank 1 to 2.5V. So now I assume I must use the 2.5V IO standard for the configuration pins ...
14 years agoHave you considered using a bus switch, rather than a buffer?
For example, consider using this part: http://www.ti.com/lit/ds/symlink/sn74cb3t1g125.pdf Your FPGA VCCIO bank powered at 2.5V would output csN and DCLK to the FPGA with 2.5V logic levels. With the EPCS powered at 3.3V, Vih(min) = 0.6*Vcc = 2V, so the FPGA signals do not need level translation. The EPCS will output a voltage of at least Voh(min) = Vcc - 0.2 = 3.1V. If you look at the sn74cb3t1g125 data sheet page 6, you can see the input-to-output response for two different power supply voltages. It looks like you could power the bus switch at 2.5V, and that would clamp the EPCS DATA signal to a little over 2V. The bus switch delay is less than 250ps. Cheers, Dave
