14 years ago2.5V VCIO for Configuration Pins
I am using a Cyclone III. I want to use the LVDS IO on Bank 1. I assume that I must set the VIO for Bank 1 to 2.5V. So now I assume I must use the 2.5V IO standard for the configuration pins ...
14 years ago --- Quote Start --- I will use a SN74AUP1G08 (SOT package) for each signal into the FPGA (ie DATA(0) and nCONFIG). Am I missing something? --- Quote End --- Is the 4.3ns delay of the SN74AUP1G08 going to be an issue? I vaguely recall someone else using level translators on the forum, and their buffer did cause a problem ... Cheers, Dave
