17 years ago16-bit 4 inputs interfacing with 16-bit 1 input of DCFIFO
hi, i'm thinking to interface these 16-bit 4 inputs to 16-bit 1 input of DCFIFO. i want the data to be written in sequence, starting from Q1 to Q4. when wrreq is asserted in DCFIFO, the output...
17 years ago --- Quote Start --- first, does the clk input in the packetbitconverter block synchronizes the Q1...Q4 outputs ? (does the Q1...Q4 outputs changes on each edge of clk ?)if yes, then fulldataclk could be connected to clk. --- Quote End --- yes, the output will be available at posedge of the clk. --- Quote Start --- fifoclk is the clock connected to the wrclk of the fifo, choose for its frequency, any value that's at least 4 times bigger than fulldataclk (so as to be able to stock all the four values Q1..Q4 in the fifo, before they change) --- Quote End --- right now, i used the same clock as clk for fifoclk(wrclk). the output at Q1 to Q4 will not change until Q4 has been transferred to fifo. is that possible to do so? i will need to de-assert "en" signal to clear the Q outputs. thanks
