10MxxDAF484 Different voltage on VCCIO1A/B and VREF_ADC pin
- 2 years ago
If you do not enable the ADC feature, you may connect VCCIO1A and VCCIO1B pins to different voltage levels, provided that the VREF pin is not used. If the VREF pin is used, you must connect the VCCIO1A and VCCIO1B pins to the same voltage level.
If you enable the ADC feature, connect VCCIO1A and VCCIO1B to 2.5V.
This is what I got from Pin Connection Guidelines for Max 10 (Dual Supply).
It checks all your recommended solutions.
Aqid
Aqid
