BQi
6 years ago10GE support 1GE in the same time in S10 MX E tile
1SM21BEU2F55E2VG,we use ipcore Intel Stratix® 10 FPGA E-Tile Hard IP to implement 10GE, we want to know the 10GE how to support 1GE in the same time ? we can not find the configuration of 1GE in the ...
Deshi_Intel
6 years agoHi,
Thanks for pointing out the SEP doc page 44. So, it matched with my explanation earlier.
Etile has 2 types of Ethernet IP.
- Etile Ethernet hard IP : support 10G, 25G and 100G.
- TSE IP : support 10M, 100M and 1G.
- But user can't switch Ethernet speed between these 2 IP as there are different IP.
- Etile doesn't support 1G/10G switching on one IP.
If your customer is interested with 1G/10G switching solution on the same transceiver channel, then may I suggest to use Ltile/Htile "1G/2.5G/5G/10G Multi-rate Ethernet PHY" IP ?
You can refer to more detail of Multirate PHY IP in below link
We also have 1G/10G switching reference design that pair with low latency 10G MAC IP.
dlim
- BQi6 years ago
How can we implement TSE soft core IP in E tile? You can solve this question firstly.
