BQi
6 years ago10GE support 1GE in the same time in S10 MX E tile
1SM21BEU2F55E2VG,we use ipcore Intel Stratix® 10 FPGA E-Tile Hard IP to implement 10GE, we want to know the 10GE how to support 1GE in the same time ? we can not find the configuration of 1GE in the ...
Deshi_Intel
6 years agoHi,
Let me clarify. There are 2 Ethernet IP.
Etile Ethernet hard IP only support 10G, 25G and 100G.
TSE is totally different Ethernet IP that just support 10M, 100M and 1G.
Just to be clear, user can't switch Ethernet speed between these 2 IP as there are different IP.
May I know why do you want to recommend customer to use TSE on Etile which is targeting high speed application like 25G to 56G ?
- Etile is very expensive to be wasted for 1G application
- For 1G application, can you recommend customer to use TSE on LVDS IO instead which is cheaper solution ?
- We do have below AN that showcase how to use TSE IP on LVDS IO but no reference design on Etile yet as it's still pretty new and hard to use.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an830.pdf
dlim
- BQi6 years ago
Customer would like to implement 10GE/1GE auto switch, so we need implement the 10GE/1GE in same transceiver. You can find the detail in https://www.intel.com/content/dam/altera-portal/sep/global/en_us/products/watermark/Stratix_10_Agilex_Update_2020_March.pdf E tile is already support 1GE in this pdf page 44. But how to do it ?
