8 years ago10AS066H2F34I1HG FIT and MTBF value
Dear sir,
Can I know the FIT(failure in time)and MTBF value of following: 1)10AS066H2F34I1HG 2)EPCQL256F24IN12 Replies
You can find information in below link. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rr/rr.pdf https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06132000_3184.html https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12222008_705.html https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04072012_59.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Can you suggest me External Temperature Sensing Diode that can be used with 10AS066H2F34I1HG?
You can use PN:MAX1619. Refer the arria10 development kit schematic for interfacing details and handbook page no:310 & 311 for connection guideline. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/arria-10/a10_handbook.pdf https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arria10/soc/production_files/a10_soc_devkit_03_31_2016.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
What is the difference between 10AS066H2F34I1hG and 10AS048H3F34I2sG? what does h and s indicates?how does it differ from each other?
Refer https://www.altera.com/en_us/pdfs/literature/sg/product-catalog.pdf https://www.altera.com/documentation/sam1403480274650.html#sam1403480019500 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Hi sir,
Thanks for sharing, I am aware of those documents you have shared. It consists of the following power option. S : Standard L : Low M : VCC PowerManager But customer has provided us with the part number 10AS066H2F34I1HG. Can i know what does that H refer to? - Altera_Forum
H refers to High performance power. For more details on this you can check the links in pervious post. https://www.alteraforum.com/forum/attachment.php?attachmentid=14710 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
We are using 10AS066H2F34I1HG. What is the allowed (minimum and maximum) ppm tolerance for input clock for FPGA DDR4 Clock and HPS DDR4 clock? Regards, Bhavishya AJ - Altera_Forum
There is no ppm spec for DDR4 refclk. Both FPGA and HPS DDR4 refclk will be connected to IOPLL input clock pin. For IOPLL input clock spec, we only have jitter spec as shown in attached A10 datasheet. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Thanks for your reply. Where can I get the following documents 1)IBIS model and associated documents 2)insertion and jitter loss documents for 10AS066H2F34I1HG? Regards, Bhavishya AJ
