100G interlaken usr_clk frequence cannot be modified
Hi Hong,
Thanks for confirming. Based on your IP configuration, you're trying with 12 lanes with 12.5GBPS lane rate.
The IP parameter editor prompts you to the recommended user clock frequency for the combination of number of lanes and data rates. The software derives the user clock frequency based on the configuration you select. The user clock frequency maps to the tx_usr_clk and rx_usr_clk signals.
Based on UG, it's suggested to used 300MHz for ideal timing. Using any not recommended clock will trigger timing error. Is there any reason you're supplying 311MHz instead of 300MHz?
Pavee
- hongsy2 years ago
Hi,Paveetirra_Srie,
Thank for your reply!
It's better for using 311mhz. But if it can't be 311mhz, i can use 300mhz.
Now i use 300mhz for testing, it still have timming warnning. The warnning is at clock ilkn_core_0|uflex_ilk_0|C2_xcvr|S10.xcvr_s10|tx_clkout|ch6 SLACK:-90.812 END Point TNS:-1179.112.
I have done severial tests. I changed follow steps it will cause the same timming warning:
1. support 311mhz clock by pin.
2. support 300mhz clock by IOpll which i generate by IP Catalog.
3. support 311mhz clock by IOpll which i generate by IP Catalog.
4. support 300mhz clock by 'iopll' a module in ip's directory(module 'iopll' also instance in design example test_infra.sv) .
I use 'iopll' and support other clock that ip needs as same as design example supprt.But it still has the same timming warning.I try to give reset synchronously, it still the same. I now don't have any idea to solve this problem. Do you have any suggestion?
Dose this problem will lead to data be changed when transmitting?
Hoping for you reply.
Thank you!
Hong
