13 years ago1 GHZ clock
Hello every one, For a project in our company we are looking for FPGAs which can operate at very high speed, with 1 Ghz clock.Is there some other way to genarate a block inside fpga using PLLs ...
13 years agoHi sarat,
As mentioned by others, 1GHz is not possible in current generation FPGAs. However, it is possible to process data sampled at 1GHz and higher data rates. The data is simply processed in parallel. If you can explain what you need to do, the forum members can provide some advice. Cheers, Dave
