13 years ago1 GHZ clock
Hello every one, For a project in our company we are looking for FPGAs which can operate at very high speed, with 1 Ghz clock.Is there some other way to genarate a block inside fpga using PLLs ...
13 years ago --- Quote Start --- Hello every one, For a project in our company we are looking for FPGAs which can operate at very high speed, with 1 Ghz clock.Is there some other way to genarate a block inside fpga using PLLs with such a High speed? any information about this topic could be very helpful for us. Thank you in advance. regards, sarat --- Quote End --- What reason do you have that you need such high clock rates inside an FPGA? If it is due to signal processing requirements then you could better use parallel processing at a lower clock.
