10 years ago1.8V LVDS inputs
Hello, I am using a Cyclone IV EP4CE15 FPGA and I need to accept 1.8V LVDS inputs from an image sensor. (100R termination, 150mV voltage swing, 0.9V common mode voltage). I am unsure how to d...
10 years agoAre you sure the common mode voltage out of the sensor is 0.9V? Table 1-20 in the Cyclone IV data sheet gives the LVDS specs. If your data rate is < 700Mbps then a common mode voltage (Vicm in the table) of 0.55V to 1.80V is allowed. If your data rate is > 700Mbps then 0.9V is out of range.
