13 years ago.sof is not genrated (urgent)
.sof is not generated. We have used megacore FFT function to build in to an IP of Qsys..it is generated without any error. but when we include this IP in our top level .sof and is not generated even ...
13 years agoAssembler Message Shows the following thing:
1. Info: Running Quartus II 32-bit Assembler 2. Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off DE0_Nano -c DE0_Nano 3. Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores. 4. Info (115031): Writing out detailed assembly data for power analysis 5. Info: Quartus II 32-bit Assembler was successful. 0 errors, 36 warnings
