JZhen1New Contributor6 years ago多FPGA JIC文件烧写失败 客户当前产品用了Intel不同系列的FPGA进行搭建,一片4CE75,一片10AX057,两片FPGA串在一个JTAG链上。 在开发过程中发现,如果用Quartus Prime 17.1,两片设备都可以识别到,下载sof文件都没有问题,但是如果烧写JIC文件,会出现现Quartus Prime 17.1的Cyclone IV的Factory default enhanced SFL imag...Show More
Recent DiscussionsEPM7064LI44-15 – Xeltek SuperPro 610P Program OK but Verify fails at address 0x50There are distinct scratches on the BGA substrate, extending beneath the solder balls.Preconfiguration BSDL Editor for Agilex 7 with disabled F-TilesMAX 10 – Sporadic configuration failure after firmware updateCheck COD for EP4CE10F17C8N
