Kavin's avatar
Kavin
6 years ago
When using RSU, is it necessary to use an external trigger to trig FPGA to load application image?
I got some problems when using RSU in Cycone IV E device:
1: When using RSU, is it necessary to use an external trigger to trigger the FPGA to load the application image? I try to use logic to trig reconfiguration after power on, if no error accurs, appliaction is load successfully,and when some contents of application image are erased, FPGA is thought to fall back to factory image ,but i found my FPGA will contiously reconfiguring.
2: Why can't I get the reason for reconfiguration by reading the register when the application image fails to load and returns to the factory image? I want to get the reason for the last FPGA reconfiguration, and based on this reason to determine whether to start loading the application image, this should avoid the FPGA into the loop reconfiguration, but never get this information through the read register.
3: The same loading process, why use the avalon-mm interface in the factory image I can not trigger the FPGA to load the application image, but the non-avalon-mm interface trig successfully?
  • Hi,
    The pof_error only performed sanity check and not full check. So if the initial bitstream is correct then it will try to configure the FPGA with application image. The pof_error will only detect if there is some error on the initial bitstream.
