SATC's avatar
SATC
7 years ago
When I'm in the programming window and trying to pass the pof file to MAX I get the following error "Cannot add target device EPCQL1024 to device chain when in current programming mode" how should I proceed? What would be the other way to programming MAX?
I have a problem programming the MAX and cyclone 10 GX. In the programming window I can set the .sof file to pass to Cyclone, but when I select the MAX .pof file I get the following error: "Cannot add target device EPCQL1024 to device chain when in current programming mode" how should I proceed? What would be the other way to pass the program to Max?
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hi Sarah,
    Is the error coming up as soon as you attach the POF to the chain? or when you are attempting to program your device?
    Are you in Active Serial Mode?
    Also, share information on board or kit, tool edition & version, and the project used.
    Anand
    • SATC's avatar
      SATC
      The error occur when i am trying to pass the POF in the programmer section
      I'm trying to program an Intel Cyclone 10 GX 10CX220 FPGA with the Quartus Prime Pro edition 19.2 version
  • Abe's avatar
    Abe
    When trying to program the Max device have you tried changing the Programming mode. If its in the JTAG mode, set it to Active Serial and then try.
    • SATC's avatar
      SATC
      in the Active Serial mode the board is not detected
    AnandRaj_S_Intel
    Okay,
    To program the MAX 10 device.
    1. Open programmer select mode JTAG.
    2. Click on auto-detect and select the device.
    3. Right-click and change the file max10.pof and click program.
    Anand
