SATC
7 years agoWhen I'm in the programming window and trying to pass the pof file to MAX I get the following error "Cannot add target device EPCQL1024 to device chain when in current programming mode" how should I proceed? What would be the other way to programming MAX?
I have a problem programming the MAX and cyclone 10 GX. In the programming window I can set the .sof file to pass to Cyclone, but when I select the MAX .pof file I get the following error: "Cannot ad...
AnandRaj_S_Intel
7 years agoHi Sarah,
Is the error coming up as soon as you attach the POF to the chain? or when you are attempting to program your device?
Are you in Active Serial Mode?
Also, share information on board or kit, tool edition & version, and the project used.
Anand
SATC
7 years agoThe error occur when i am trying to pass the POF in the programmer section
I'm trying to program an Intel Cyclone 10 GX 10CX220 FPGA with the Quartus Prime Pro edition 19.2 version
