VLor0's avatar
VLor0
6 years ago
What programming cable supports the Cyclone EP2C5F256C8 device? I am using the USB Blaster and it doesn't seem to allowing me to program the device. The link below doesn't not list the Cyclone II.
    • VLor0's avatar
      VLor0
      Aiman, Thanks for the reply. I am trying to examine the checksum from the Cyclone EP2C5F256C8 device? However, when I do a auto detect in the programming mode it detects the device, but it will not allow me to select any of the features: examine, program, verify, etc..? Do you know why? Best Regards, Vue Lor | Engineer RDM Industrial Electronics, Inc. 850 Harmony Grove Rd. | Nebo, NC 28761 Phone: (800) 282-5183 | Fax: (828) 652-2697 Email: [email protected]
  • Hi Vue Lor,
    -May I know how did you perform this configuration?
    -What did you see when you were performing this? Is the feature grey out?
    -are you not able to select or is it a functionality problem?
    -What file did you use: .sof?.pof?
    -what is the bitsream?
    Aiman
    • VLor0's avatar
      VLor0
      Aiman, I am using Quartus II 13 SP1 on a Window 7 64 bit, when I open Quartus. I go in the Tools tab and pick programmer. I do auto detect to detect my device, but then all the features are grey out and will not allow me select any feature? Best Regards, Vue Lor | Engineer RDM Industrial Electronics, Inc. 850 Harmony Grove Rd. | Nebo, NC 28761 Phone: (800) 282-5183 | Fax: (828) 652-2697 Email: [email protected]
  • Hi,
    Did you do the hardware setup? Can you show me what is your hardware setup?
    Aiman
    • VLor0's avatar
      VLor0
      Aiman, Evidently, I figured that the EP2C5 wasn’t programmable? However, I am using Quartus 13 SP1 and USB Blaster on Windows 7 OS 64 bit, but for now I think I am ok. thanks for all your help? Best Regards, Vue Lor | Engineer RDM Industrial Electronics, Inc. 850 Harmony Grove Rd. | Nebo, NC 28761 Phone: (800) 282-5183 | Fax: (828) 652-2697 Email: [email protected]
  • Hi Vue Lor,
    I apologize that i am not helping so much on your issue. Good to know you are OK. I will proceed to close this case if there is no further request. Feel free to post a new case if you have another request.
    Thank you.
    Aiman
