eMagii
6 years agoWhat is the effect of nCE on passive serial configuration
We have a board with two Cyclone 10LP FPGAs connected to a processor. The processor runs u-boot/linux. The configuration will be done in u-boot. We would like to configure the FPGAs in any order, ...
eMagii
6 years agoCould you explain how you program FPGA #2, without programming FPGA #1?
As far as we know, this is not possible, but it is a requirement for us.
Our design looks like:
We plan to have a programming cycle like this for Device 1 in our diagram.
As far as we understand, both Device 1 and 2 in our diagram are connected as FPGA Device 2 in your picture.
That is: the device will see nCONFIG pulsed low, while its nCE is high.
So we have the following questions about device #2 in the passive serial programming for multiple FPGAs.
- Can you confirm that device #2 in your diagram is reset when nCONFIG goes low even though the device is disabled (nCE is high)?
- Can you confirm that device #2 in your diagram is not affected by any transitions on DATA0, DCLK while the device is disabled (nCE = high)?
- Can You confirm that once the set number of configuration bytes have been sent on DATA0, DCLK any bytes following that are ignored.
- Can you confirm that once nCE goes low on device #, incoming data is accepted immediatel(no delay)?
- What happens with the I/O pins if nCE goes high after configuration?
We see that this is how it is going to look like for a full configuration.
Best Regards
Ulf
