dsmirnov
7 years agoWhat is JTAG Debug Level 3 for Nios II?
Hello everyone, I would like to trace program execution on the Nios II. One way - to buy Lauterbach - not interesting. Second way - use SignalTap II and .objdump file - pretty well, but still. And n...
Ahmed_H_Intel1
7 years agoHi,
The debugger level shows the level of targeted components in the debugger. The following video show you how to debug a NIOS II application
https://www.youtube.com/watch?v=VExM1gtWUCA
Note: Normally you must set the optimization and debug levels the same for the application,
the BSP, and all user libraries in a software project. If you mix settings, you cannot
debug those components which do not have debug settings. For example, if you
compile your BSP with the -O0 flag and without the -g flag, you cannot step into the
newlib printf() function
- dsmirnov7 years ago
Dear Embedded_guy,
Thank you for your answer. I watched the video and it is just about regular software debug, while I'm asking
about Tracing mode and profiling the code. I understand how to use Debug, but sometimes it is not enough.
I found trace working in Nios II EDS with Quartus 10.0, but in fresh Nios SBT there is nothing about it.
I can choose on of five levels of debug, anf the 3rd one tells, that I can use On-chip trace.
I also don't understand your phrase "The debugger level shows the level of targeted components in the debugger."
By the level of targeted components - what do you mean?
Also thank you for your note, I've checked flags for compilation, they are identical
- ABola27 years ago
Thanks Embedde guy for this Note.
