15 years agoUsing VIP Suite
I want to ask if we can use the Altera Vip Suite components fully to perform image processing operations even if I do not have the license of Quartus i.e. with the time limited version.. Thnks Sneha7 Replies
You can develop using OpenCore license. If You need to use cores on the final product - You need to buy the suite.
Thanks I aslo want to know if I can simulate my design using the modelsim PE student edition because I tried it and it is giving me license errors with DDR and cpu
Better use ModelSim Altera Edition. There's a free one.
Hi, Thanks for suggestion I switched to Altera Modelsim but I still have the problem that when I am trying to compile my design with simulator turned on it is giving me error with DDR2 memory.
Error: Can't generate netlist output files because the license for encrypted file "D:/DVI_3/All_Workin_codes_14July/DVI_Loop_through_C120_Sneha_Nidhi_Workin/DVI_1080P_Loop_through_C120_Beta_1/hsmc_dvi_1080p_c120_beta/hsmc_dvi_1080p_c120/auk_ddr_hp_controller.vhd" is not available - Altera_Forum
There should be core simulation model. Check the project directory.
I am getting these errors while comiplation in the Quartus II 10.1 sp1.
--- Quote Start --- There should be core simulation model. Check the project directory. --- Quote End --- I didnt understand what you are trying to say here in the post?
