16 years agousing RAM memory on de1 board (Cyclone II)
hellol,
I have a question about reading and writing from the RAM memorys that are on-board of the DE1. from what i have read: there are 3 types of memory installed: 8Myte SDRAM, 512 Kbytes Sram , 4Mbytes flash. i want to use the ram memory (dont know who should i choose) and found this code templtae in quartus: --- Quote Start --- -- Quartus II VHDL Template -- Simple Dual-Port RAM with different read/write addresses but -- single read/write clock library ieee; use ieee.std_logic_1164.all; entity simple_dual_port_ram_single_clock is generic ( DATA_WIDTH : natural := 8; ADDR_WIDTH : natural := 6 ); port ( clk : in std_logic; raddr : in natural range 0 to 2**ADDR_WIDTH - 1; waddr : in natural range 0 to 2**ADDR_WIDTH - 1; data : in std_logic_vector((DATA_WIDTH-1) downto 0); we : in std_logic := '1'; q : out std_logic_vector((DATA_WIDTH -1) downto 0) ); end simple_dual_port_ram_single_clock; architecture rtl of simple_dual_port_ram_single_clock is -- Build a 2-D array type for the RAM subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0); type memory_t is array(2**ADDR_WIDTH-1 downto 0) of word_t; -- Declare the RAM signal. signal ram : memory_t; begin process(clk) begin if(rising_edge(clk)) then if(we = '1') then ram(waddr) <= data; end if; -- On a read during a write to the same address, the read will -- return the OLD data at the address q <= ram(raddr); end if; end process; end rtl; --- Quote End --- now, i undestand that it does an 2-D array but there i things that i dont figure: 1. if the adress witdh is 8 and word size is 6 that makes a: (2^8 *6) = 512bit memory right? 2. how can i connect this entity for it to use the wanted memory? 3.what memory should i choose:SRAM or SDRAM (i need to work on dual mode) thank alot Pini Sberro2 Replies
Your design is using FPGA internal RAM, obviously the best idea with a rather small memory unit. It's the only memory, that can be operated dual-port, as intended. Alls external memories are single port.
From the external memories, only SRAM is available for simple interface. But you have to connect all memory signals to your design. - Altera_Forum
thats bad news for me.
I was asked in class to use the external memory. But i was told that it support dual mode too, are u certain its not? And Is there a simple way to write to the external memories? Thanks alot
