Use Mictor-38 HPS JTAG on HPS IO-48 OOBE Daughter Card Stratix 10 SX Development Kit.
Hi SSB
Happy New Year! Sorry for the late reply.
Is there a special use case that require you to use an external JTAG? There is an internal JTAG in in the Stratix10SX Devkit that you could connect to using only a USB Cable. I would recommend to use the internal JTAG.
Are you able to flash the DevKit using the Quartus Flash Programmer?
Initially the HPS would not be showing in the JTAG Chain if it is not enabled.
Could you try the steps to boot the board from QSPI with the steps below:
https://www.rocketboards.org/foswiki/Documentation/Stratix10SoCGSRD#Booting_from_QSPI
You would need to flash the "ghrd_1sx280lu2f50e2vg.hps.jic" and boot the board from QSPI.
After that you would see the HPS appearing in the jtag scan.
The SOF file that you are using is only temporary and not permanent, that could be the reason why you are not seeing the HPS.
Jingyang, Teh
