Rajatkumar1
3 years agoURGENT-Need alternate for EPM240M100C5N
Hi, I am using EPM240M100C5N in my Project/application. This is going to obsolete in near future. There is no stock for this part from any Distributor. I am not able to find alternate part for this...
Mengzhe
3 years agoHi,
As you mentioned that you don't want to change PCB, I found MAX V devices 5M160Z, 5M240Z and 5M570Z which have same packaging as EPM240 (MBGA pin) please ask supplier if these devices are available.
But for devices cross family there is no direct migration solution. You have to manually migrate the pins, power characteristic and IP variants among different devices.
For example, you need to check if each pin is corresponding to each other between MAX II and MAX V devices using pin-out files.
Mengzhe
