Understanding SW3 settings in Agilex Devkit
- 4 years ago
Hi anrfpga
Sorry for the multiple confusion through the thread.
"Chained HPS with SDM nodes internally" refers to the HPS is chained to the SDM through the FPGA silicone and the HPS is connected to the JTAG chain through the SDM Jtag Pins.
"Chained HPS with SDM nodes externally" refers to the HPS not connected to the SDM. The HPS will be connected externally through the OOBE daughter card through its own dedicated JTAG pins.
For mode 001 to enable the HPS on the Jtag chain, it requires an additional OOBE daugther card for the HPS to be able to appear on the JTAG chain.
Jingyang, Teh
Hi Jingyang,
I am using the GHRD FPGA configuration. But, I am not sure how that impacts the JTAG chain.
Based on your reply, I tried more configurations. The first one with ON/OFF/ON/ON/ON/OFF/ON/ON (SW3.2 and SW3.6 are OFF = MAX10 FPGA enabled) was working fine and had the AGFB014 and MAX10 in the JTAG chain and the second one with OFF/OFF/ON/ON/ON/OFF/ON/ON (SW3.1, SW3.2 and SW3.6 are OFF = Both HPS and MAX10 enabled) had a broken chain issue. I have attached the JTAG debugger error.
So, with internal USB blaster cable, is the second configuration invalid?
