Understanding address map in EMIF
- 4 years ago
For the address ordering that you used:
CS-CID-Row-Bank-Column-BG
The CS is available only when there is multiple rank.
The CID is for 3D stacked interface. No CID bit in this configuration.
Row address width = 15.
Column address width = 10.***
Bank address width = 2.
Bank group width = 2.
***(Lower 3 bits has been set to 0 because Avalon bus is 8x wider than EMIF bus in Quarter rate. Therefore it's removed when mapping to Avalon address)
The ordering will be as below:
Row[14..0] = amm_address[25..11]
Bank[1..0] = amm_address[10..9]
Column[9..3] = amm_address[8..2]
BG[1..0] = amm_address[1..0]
Hi Mahdi,
Thank you for submitting your question in Intel Community.
I'm Adzim, application engineer will assist you in this thread.
In my opinion, you need to refer to memory datasheet for the truth table of the memory commands.
Cheers,
Adzim
- Mahdi4 years ago
Hi Adzim,
Thanks for your reply. I am not using the actual memory system. I am using the memory IP core that is generated in EMIF design example, and I do not know its specifications.
- Mahdi
