mehta_expai
4 years agoTripple speed ethernet IP
I have triple speed ethernet ip from collateral file of cyclone 10 gx. I want implement this xcvr block for sfp compatible. Which ip blocks should be added with this triple speed ethernet ip...
mehta_expai
4 years agoHello,
From now we have taking the same approach as you suggested. Their is a doubt regarding one IP . That IP name is Avalon Memory Mapped Master translator IP. It is not included in IP catalog of Quartus 2 prime pro. You have any document or design example from where i can use it.
Thanks for reply.
- skbeh4 years ago
Contributor
You can refer to below Platform Designer user guide, see section '5.1.3.2. Avalon Memory Mapped Host Translator'
https://www.intel.com/content/www/us/en/docs/programmable/683609/21-3/creating-a-system-with.html
Depends on the Quartus version you are using, the previous component could be has been renamed.
