mehta_expai
4 years agoTripple speed ethernet IP
I have triple speed ethernet ip from collateral file of cyclone 10 gx. I want implement this xcvr block for sfp compatible. Which ip blocks should be added with this triple speed ethernet ip...
skbeh
Contributor
4 years agoFrom TSE IP usage and concept point of view, Arria 10 and Cyclone 10 are the same.
To run the example design in Cyclone 10, one can port over the Arria 10 example design to target Cyclone 10 device. i.e. by changing the device OPN, transceiver RX/Tx pin assignments, clock pin assignment, regenerate the IP and design in Quartus.
