This is important case found IC Intel/Altera Stratix® III Devices Failure [MFG PN: EP3SL70F780C4NAB] Failure during ICT [In-Circuit Test] under IBM BU. The failure symptom is FPGA Power +3.3VE Load to GND.
Hello Wani,
Herewith below more additional the details per yours inquires.
Shall you expedite review and provide support with ERMA# and Shipping Instruction to drop return affect Stratix® III Devices Failure back to Intel/Altera Corporation perform the analysis ?
We got e-mail from your private message for return process BUT no attached file for shipping guidelines.
Appreciate for your support.
1. Please provide full device details.
1.1. Device name: Stratix III
1.2. Full part number: EP3SL70F780C4NAB
[CTH] Herewith below full device marking information.
SN: 11S00E7972YL11UE91M152
Marking: ALTERA
EP3SL70F780C4NAB
J CAFA71901A
KOREA
S848AFAZ
361JA8X0C
SN: 11S00E7972YL11UE91M121
Marking: ALTERA
EP3SL70F780C4NAB
J CAFA71901A
KOREA
S848AFAZ
361JA8X0C
SN: 11S00E7972YL11UE91M147
Marking: ALTERA
EP3SL70F780C4NAB
J CAFA71901A
KOREA
S848AFAZ
361JA8X0C
2. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
[CTH] 13889 DPPM [Failed 3 out of 216 units]
3. What is the failure symptom? Please elaborate the failure symptom in detail.
[CTH] The failure symptom is FPGA Power +3.3VE Load to GND.
4. When did the failure happen? How did you discover the failure?
[CTH] Found Stratix® III Devices Failure [MFG PN: EP3SL70F780C4NAB] Failure during ICT [In-Circuit Test].
To confirmed failure through test step debug and can be duplicated failure with FPGA Power +3.3VE Load to GND.
Once replaced known good FPGA and re-tested to confirm the failure then its passed.
5. How did you determine the failure? Please elaborate the procedures.
Step1: Visual inspection board
Result : no any defect found
Step2: Verify by digital multimeter at +3.3VE To GND.
Result : Failed. Measure= 5 ohms, normally =~592 ohms. This compare with the good board.
Step3: Send Board to rework remove BGA Location UFPGA2 for confirm between pad pcb or UFPGA2
Result: Load in component (replace new part UFPGA2)
Step4: Confirm the board and component by send to re-test ICT [In-Circuit Test].
Result: Pass
6. Does the failure unit ever working before failure?
[CTH] Yes
7. Did they violate solder re-flow temperature profiles, moisture sensitivity? Please provide the re-flow temperature profiles.
[CTH] No any deviate solder re-flow temperature profiles and moisture sensitivity. The re-flow temperature profiles need to get approve from customer. Will keep you post update.
8. Did you swap the failure device to a known good board? Is the failure following the device or board?
[CTH] No. BUT Once replaced known good FPGA Units and re-tested to confirm the failure then board can have passed.
