covfefe
3 years agoSystem-Console device_load_sof SEVERE crash on Stratix 10
I am running into an issue, where trying to load an *.sof via the system-console crashes (both command line device_load_sof and GUI: Device>Program Device).
I have the same issue regardl...
covfefe
3 years agoHere are more log files of errors seen, sometime resulting in a java crash.
Feb 06, 2023 9:47:13 AM com.altera.systemconsole.internal.core.SystemConsole logInfo INFO: Finished discovering USB connections Info (19848): Regular SEU info => 105 sector(s), 8 thread(s), 10000000 interval time in microsecond(s) Info (19848): IO hash is A08D0413E892EE9BEFB02EDC069509C223C74B95BC45D3232EFEBB4F109D993E Info (19848): Keyed hash is C72FC6717073F74321069028720DCC47EE8CFD6C94E9D5F09E10E6A887598B0C Info (19848): Design hash is D16EDFC4FC09CCE805033D7A9675C9A5B743393DEF219493D586D4388EE3DCCC Info (19848): IO hash is A08D0413E892EE9BEFB02EDC069509C223C74B95BC45D3232EFEBB4F109D993E Info (19848): Keyed hash is AC65047A4F4220AB72BCC70F65506F1C583D665B554F487D30475A5AA5EFFDEF Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Command: quartus_pgm --no_banner --mode=jtag --cable="USB-BlasterII on localhost [USB-1]" --operation="p;C:\fpga_s10-1-15-spi-lock-fix.sof@2" Info (213045): Using programming cable "USB-BlasterII [USB-1]" Info (213011): Using programming file C:/fpga_s10-1-15-spi-lock-fix.sof with checksum 0x47DB41BB for device 1SG280LU2F50@2 Info (209060): Started Programmer operation at Mon Feb 6 09:47:24 2023 Error (18939): Unexpected error in JTAG server: Conflict with another device - check Error (209012): Operation failed Info (209061): Ended Programmer operation at Mon Feb 6 09:47:24 2023 Error: Quartus Prime Programmer was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 1670 megabytes Error: Processing ended: Mon Feb 6 09:47:24 2023 Error: Elapsed time: 00:00:17 Error: System process ID: 14300 Feb 06, 2023 9:47:24 AM com.altera.systemconsole.scripting.TCLCommand execute2 SEVERE: device_download_sof: Unable to load the sof: C:\fpga_s10-1-15-spi-lock-fix.sof Feb 06, 2023 9:47:24 AM com.altera.systemconsole.internal.core.SystemConsole logInfo INFO: Finished discovering JTAG connections Feb 06, 2023 9:47:24 AM com.altera.systemconsole.internal.core.SystemConsole logFine FINE: Connection type JTAG hash NULL index null device 1 Throw DebugException: error -6 # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffb24cfa840, pid=20996, tid=0x0000000000005364 # # JRE version: Java(TM) SE Runtime Environment (8.0_212-b10) (build 1.8.0_212-b10) # Java VM: Java HotSpot(TM) 64-Bit Server VM (25.212-b10 mixed mode windows-amd64 compressed oops) # Problematic frame: # C [DtsFrame64.dll+0xa840][thread 5364 also had an error] # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows # # An error report file with more information is saved as: # C:\Users\covfefe\AppData\Local\Temp\\hs_err_pid20996.log # # If you would like to submit a bug report, please visit: # http://bugreport.java.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. #
