Stratix10 htile physical GPIO pins missing.
Is this a dev kit? Which one? And what do you mean the pins are missing? They would be connected to some type of board connector or jumper if they are available for user access on a dev kit.
- Rah171 year ago
yes, it is a development kit. it is Intel stratix 10 sx Soc development kit.
Daughter card has access to 7 gpio on the HPS side. those 7 gpio is used by leds ,ethernet etc. I would like to use those 7 GPIOs. is there any way to get a physical pinout so that i can connect a test chip with the gpios exposed to daughter card.
- sstrell1 year ago
It doesn't look like there is a connector on the daughtercard for this.
It's your board. There's nothing stopping you from removing the LEDs, buttons, or ethernet connector.
Or maybe there is a different board you could use that brings out all the signals to pins. The Samtec connector is pretty standard. Maybe there's an Arduino-related board available.
- Rah171 year ago
There is 2 GPIO controller in the HPS side. It can support upto 48 pins. I am attaching the block diagram 2.2.1. HPS Block Diagram.
But there is no physical GPIO pins. How can I access this. Is FMC a way? . Can i attach a breakout board to FMC and get the physical GPIO pins. Is the FMC on stratix 10 board connected with this GPIO on the HPS side.
Please do mention if there is any other way to get GPIO pins out so that i can attach my test chip.
Thankyou
