jkhoo
3 years agoStratix V IO pins in bank C & D cannot ramp to 3.3V when VCCIO is source with 3.3V
Why is there difference in voltage level in bank 3C/3D IO pins when setting the current strength between 8mA, 12mA versus 16mA? I am expecting 3.3V on the IO pins but only get 1.5V when setting the c...
AqidAyman_Altera
3 years agoI would suggest you to not trying something out of spec as it is not guaranteed for the performance and might damaging the device.
I can suggest you use lever shifter to convert signal to 3.3v as this is safer implementation. Lever shifter is an external component to convert signal voltage level.
