9 years agoStratix V Advanced Systems Development Kit SW4 Default Settings
The documentation for the stratix v advanced systems development kit (https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-stratix-v-advanced.html) seems to be incorrect in regards to ...
8 years ago --- Quote Start --- As the original poster for this thread, I would just like to say that I appreciate Dav's efforts. It is definitely an issue for all of us who bought this board, but it really isn't Terasic's nor Altera's problem. We bought something on Ebay and hence it really is caveat emptor. Hopefully, with some good faith and gesture, Dav and Terasic comes through with some documentation to help us poor saps. The board is not a waste and hence can be utilized, but documentation is needed. BTW, the software from Intel was written in JAVA, and hence a bit of reverse engineering can produce the source code :) QG --- Quote End --- I have ended up with two of these dual FPGA “Advanced Systems Development Kit” boards as well, paying quite a bit ($4800 each) and unfortunately not realizing these are not the device I thought they were. My serial number on one is 5SGXAS00000236 and P/N 0277 0K. i noticed the problem when I saw the QDR and MoSys missing, but I had been traveling so have no window to return. Can we at least have the pin assignments so we can use these boards? :( this is stomach unsettling.
