JELogan
3 years agoStratix 10 I/O Maximum Frequency
For a particular design I have an external, 1 GHz, clock. An ideal solution would be to use this clock to clock some FPGA logic. I aim to use a 1:1 PLL clock to help improve timing and clock routing ...
AqidAyman_Altera
3 years agoHi,
Thank you for reaching out Intel FPGA Community.
According to this Knowledge Base article, refer here Will Altera publish the maximum I/O toggle rate specifications for... (intel.com), unfortunately we are not published the maximum IO toggle frequency in the datasheet for newer device anymore.
All of the standard supported I/O signaling frequencies is depended on design and also system customization form factors.
Therefore, the I/O toggle rate specifications was being removed from Stratix 10 device datasheet. The best options are using HSPICE or IBIS simulations.
Aqid
