JSambrook_CSSI_FPGA
3 years agoStratix 10 GX L-Tile Dev Kit and PCIe
Hello -
I have one of the Stratix 10 GX development kits, the L-tile version.
The card is installed in a Dell Precision 5820 chassis, in slot 4, a x16 Gen3 slot.
I'm looking for a known-goo...
Wincent_Altera
3 years agoHi,
I wish to follow up with you about this case.
Is there any method that I can provide the .sof file to you as the file is unable to upload in this forum thread.
- The .sof file is quite easy to generate by generating an example design, example PCIe Avalon ST.
- Run the synthesis/full compilation.
- Open the signal Tap, and capture the signal as below to check the LTSSM linkup/enumeration/
Hoping to hear back from you.
Wincent_Intel
- JSambrook_CSSI_FPGA3 years ago
Hi Wincent,
Thanks for your reply. I can send you credentials to store the file on my Dropbox.
Is there are direct email address I can use that will reach you?
I don't to post the credentials in an open forum here.
You can also try my email address at Protonmail if you want: [email protected].
John Sambrook
Common Sense Systems, Inc.
